IAP215 and IAP207 Clustering problem
  • 1.  IAP215 and IAP207 Clustering problem
    Posted May 26, 2020 02:18 AM
    I have already installed IAP215 and it work fine.After certain time my network has been expand so i also used 207 to expand the network. But it did not include in the cluster also did not show SSIDs(Same IP range and network).
  • 2.  RE: IAP215 and IAP207 Clustering problem
    Posted May 26, 2020 03:09 AM
    What version are the IAP 215 running? IAP 207? Are they placed in the same management vlan? Do you have auto-join enabled on the IAP-215? If you login to the IAP 207, do you see it in a different cluster?
  • 3.  RE: IAP215 and IAP207 Clustering problem
    Posted May 26, 2020 03:28 AM
    Yes It has same version and both are in the same Management vlan 1. its auto join is enable. over that it is not comes in the cluster.
    THANKS FOR REPLY
  • 4.  RE: IAP215 and IAP207 Clustering problem
    Posted May 26, 2020 03:46 AM
    What is the version that you are using? Are the 207 APs of the same regional code (Example RW or US) like the 215 that you have?
    Do you have NTP configured (in case you were using cluster-security)?
    Does the 207 have any previous configuration? Did you try to factory reset it?
    Did you try to check the logs using show log system command?
    I would contact Aruba TAC Support to have a look if the issue persists..
