Re: IAP305 SSID won't showup
What channel is the access point on?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
I tried 2 patterns.
1. with default instant SSID
I don't know which channel the default instant SSID use
2. with customized channel, I set the following
For 5GHz: 36, 40, 44, 48
For 2.4GHz: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 12, 13
Used wifi analyzer to see if there's any signal, but couldn't find one.
Any idea ?
What regulatory domain?
Contributor I
Any output of "show ap bss-table"?
If so, what are the used channels?
How do I get the reguratory domain ?
This is what it shows.
Looks like no bss or channels ...
# show ap bss-table
Aruba AP BSS Table
bss ess port ip phy type ch/EIRP/max-EIRP cur-cl ap name in-t(s) tot-t
Channel followed by "*" indicates channel selected due to unsupported configured channel.
"Spectrum" followed by "^" indicates Local Spectrum Override in effect.
Num APs:0
Num Associations:0
What is the output of "show log system"?
There are many logs complaining about activation of provision failed...
c8:b5:ad:c4:9b:f4# show log system
Aug 19 03:28:54 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 03:33:56 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 03:38:58 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 03:40:46 cli[14131]: <341101> <WARN> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Execute command-exit.
Aug 19 03:44:00 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 03:49:02 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 03:54:04 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 03:59:10 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: protocol-error-001
Aug 19 04:04:08 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:09:11 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:14:12 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:19:15 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:24:17 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:29:19 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:34:21 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:39:23 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:44:25 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:49:27 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:54:29 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 04:59:31 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:04:34 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:09:36 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:14:38 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:19:43 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:24:42 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:29:44 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:34:46 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:39:50 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: protocol-error-001
Aug 19 05:44:50 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:49:52 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:54:54 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 05:59:56 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:04:58 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:10:00 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:15:02 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:20:05 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:25:07 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:30:09 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:35:11 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:40:13 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:45:15 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:50:17 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 06:55:19 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:00:21 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:05:23 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:10:25 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:15:27 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:20:30 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:25:32 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:30:35 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:35:37 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: protocol-error-001
Aug 19 07:40:39 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: protocol-error-001
Aug 19 07:45:40 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 07:50:43 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: protocol-error-001
Aug 19 07:55:44 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:00:46 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:05:48 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:10:50 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:15:52 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:25:56 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:30:58 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:36:02 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:41:02 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:46:05 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:51:07 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 08:56:09 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:01:11 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:06:13 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:11:15 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:16:17 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:21:19 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:26:21 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:31:23 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:36:26 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: protocol-error-001
Aug 19 09:41:27 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
Aug 19 09:46:29 cli[2115]: <341005> <ERRS> |AP c8:b5:ad:c4:9b:f4@192.168.1.251 cli| Activate provision failed, code: fail-prov-no-rule
It seems like you should contact TAC. Your access point seems to be in activate (the cloud) but if you just purchased them, they should not be.
