Re: IAP305 SSID won't showup
Thanks Colin for all the help.
I'll contanct the TAC.
Let me just summarize my current situation.
- my IAP305 seems to be activated on cloud
- it should not be activated if it's right after the purchase
- and that seems to be causing a problem
Is that correct ?
That is what it might be, based on the logs.  They could find more things in the logs to indicate otherwise.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Thanks Colin for your patient support.
Really appreciate it.
Hl, i have the same situation but with an IAP375, i enter the instant and then i create the SSID and dont show up, i try several times but dont work, did the TAC solve this, thanks a lot
The IAP375 requires newer firmware than the IAP305, so this is likely a different issue. Please start a new thread if you're still needing assistance with this.
Charlie Clemmer
Aruba Customer Engineering
