Update:
I have adjusted the IPM priorities as follows:
AP08 (config) # ipm
AP08 (ipm) #
ipm-power-reduction-step-prio ipm-step disable_usb priority 6
ipm-power-reduction-step-prio ipm-step disable_alt_eth priority 5
ipm-power-reduction-step-prio ipm-step radio_2ghz_chain_2x2 priority 4
ipm-power-reduction-step-prio ipm-step cpu_throttle_25 priority 3
ipm-power-reduction-step-prio ipm-step cpu_throttle_50 priority 2
ipm-power-reduction-step-prio ipm-step cpu_throttle_75 priority 1
After committing this changes the System Status LED on the AP-515 turned to Green and the Power Status reports that there are no more restrictions on the radios:
Power Status
Item Value
Power Supply : POE-AF
LLDP Power : Successfully negotiated at 13.0W
Current Operational State : 2.4GHz radio: No restrictions, 5GHz radio: No restrictions
Eth0 HW POE status : POE AF, LLDP power: 13.0W
What is interesting:
The System Status does not reflect that anything is disabled.
But eth1 and USB are disabled.
What is not clear to me regarding the "Tip of the Week" document:
The following options are available within the IPM config:
‘cpu_throttle_25’ Reduce CPU frequency to 25%
‘cpu_throttle_50’ Reduce CPU frequency to 50%
‘cpu_throttle_75’ Reduce CPU frequency to 75%
In terms of priority, the higher priority assigned to a setting would be a lower value. A priority value of ‘4’ would be applied before a priority value of ‘1’, etc. Additionally, on settings that apply to the same feature (CPU, radio chains, etc), they should be prioritized accordingly so that the lower-impact setting is applied before the higher impact setting.
So the correct priorities - in contrast to the documented example - should therefore be:
ipm-power-reduction-step-prio ipm-step cpu_throttle_75 priority 3
ipm-power-reduction-step-prio ipm-step cpu_throttle_25 priority 1
With regards
Manfred M.
