Installed Aruba access points and now can not print over wifi
  • 1.  Installed Aruba access points and now can not print over wifi
    Posted Oct 30, 2018 01:01 PM
    Hey all,
    I installed a few access points for a client and now they can not print over wifi. They are still able to print when they have a wired connection. Temperarily I set up their old access point so that they can print but it is very inconvenient for them. Does anyone know any fixes to the problem?
  • 2.  RE: Installed Aruba access points and now can not print over wifi
    Posted Oct 30, 2018 04:08 PM
    Are these Instant APs?  Try disabling broadcast filtering on the SSID.
  • 3.  RE: Installed Aruba access points and now can not print over wifi
    Posted Oct 30, 2018 08:01 PM
    Thanks for the feedback. I'm sorry that i'm sort of a noob but can someone let me know how I can do this
  • 4.  RE: Installed Aruba access points and now can not print over wifi
    Posted Oct 30, 2018 08:15 PM
    Can you edit the SSIDs you created?
  • 5.  RE: Installed Aruba access points and now can not print over wifi
    Posted Oct 31, 2018 11:44 AM
    Yes, i can.
  • 6.  RE: Installed Aruba access points and now can not print over wifi
    Posted Oct 31, 2018 12:29 PM
    Do I need to change the SSID?
  • 7.  RE: Installed Aruba access points and now can not print over wifi
    Posted Nov 01, 2018 07:04 AM
    Yes, you would need to change broadcast filtering to none, if this is Aruba Instant.
  • 8.  RE: Installed Aruba access points and now can not print over wifi
    Posted Nov 01, 2018 11:13 AM
    Thank you cjoseph.
    I'm sorry but can you tell me where to go to turn off broadcast filtering. I've been trying to look for the place to change it but haven't been able to.
  • 9.  RE: Installed Aruba access points and now can not print over wifi
    Posted Nov 01, 2018 11:26 AM
    Is this an Instant, or Aruba Controller based deployment?
  • 10.  RE: Installed Aruba access points and now can not print over wifi
    Posted Nov 05, 2018 05:38 PM
    I got it to work after disabling broadcast filtering. Thank you for the help! To find broadcast filtering you click edit next to the network you want to print from in the gui.
