Highlighted
Re: Intel Centrino 6205 and AP-225 headaches
You can assign an 802.11k profile for each SSID, so yes, you can turn it off or on.
Most clients don't support or leverage 802.11k anyways so you can turn it off without any ill effect.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Occasional Contributor I
Thanks Colin,
Just wanted to confirm. A large portion of clients on my environment are smart phones (iPhones and Androids). Would roaming be negatively affected if I did this?
Best Regards,
Sean
Highlighted
Roaming will definitely work without 802.11k
