Re: Interface errors
@Javin.Craig wrote:
Yeah, just easier to troubleshoot missconfigurations remotely than it is physical. Thanks.  Will report my findings after changing out physical interfaces.
Javin.Craig,
Is there a VLAN on the switch side of the trunk that is not configured on the Controller side of the trunk, or is it even a trunk?
Try matching VLANs on both sides and see if it remedies the issue.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Clear the interface counter and start with changing the fiber patch between the 2 switches. If that does not help then replace the GBICs and see what happens.
