Highlighted
Contributor I
Re: Issues with AP 510 series and Windows devices
It is the association that Im struggling with, when i look under wireless LAN profiles in the test group I have no option to select a HE profiletest ax.JPG
Im guessing that I permit that somewhere else?
Highlighted
Contributor II
@mmacleod wrote:
What would be the best way to set up a test environment to guage the impact for our wireless users?
My plan was to create a test AP group that only contains AP515's in one location and then get a subset of various users to test the impact of running with older drivers.
However when I go into the profiles for a test AP group, there is no option for turning off .ax features? It seems to be a global setting?
How are people testing this? I can set up a custom profile that has no .ax functionality, Im just not sure how to tie that in to an AP group?
Please note this is NOT done on an AP group basis. This is done on a WLAN basis. If you want to test this without effecting production. I would create a new AP group, a duplicate SSID profile with a different name and a HE profile. Once you have this you can do the below to enable HE.
You can make a new HE (High efficiency) profile here:
Configuration > System > Profiles > High-efficiency.
If you tick it, then thats AX enabled, unticked is disabled. I suggest you make a new profile compltely so you dont change production.
Once you have made your profile, navigate to:
Configuration > System > Profiles > SSID > THE NEW SSID PROFILE YOU HAVE MADE > High-efficiency SSID and select your profile here. and then sumit and push your pending changes
Any questions then please let me know. - If this answers your question, please mark this as a solution.
Ben Casey
Highlighted
Frequent Contributor I
Oh that's completely correct. My mistake. It's per SSID.
Highlighted
Hi Ben,
    I couldnt find the HE profile on Aruba Central, do you know where can i find it?
Thuc
Highlighted
Go inside your SSID config...
and look for 802.11ax
