Highlighted
License Issues
Hey all!
Just loaded 8.6.0.5 on a 7008. Controller is setup in standalone mode. On the web GUI I have no License page. I manually added (via the CLI "license add..." command) an AP count license and a PEFNG license. after adding the PEFNG license it mentioned something about enabling the feature. Tried to enter the command referenced in the licensing guide about enabling it on standalone controllers, but it throws an error about only being allowed on the mm. A "show license client-table" shows the FeatureBit for PEF module as "disabled".
So two questions. One - why is there no license page on my standalone controller? Two - how do I enable the FeatureBit for the PEF license (or do I even need to?)?
TIA!
Accepted Solutions
Highlighted
Re: License Issues
Ok, found it (attached)...it moved around a bit...
View solution in original post
All Replies
Highlighted
MVP Guru
Re: License Issues
Within the GUI on a Standalone, you need to be at the ' Mobility Controller' level, not the '
'Mobility Controller > [Controller Name]'  level to view the licenses. From here you can enable the feature bit. If you need to do it on a CLI you can also do the following:
license-pool-profile-root
    pefng-licenses-enable
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
Re: License Issues
That's part of what I'm saying. It's throwing an error that it has to be on the mobility master (even though it's configured as standalone). See attached.
Highlighted
Re: License Issues
