Licensing
Hello Team,
Can anybody help me with the below exam question ?
A company plan to deploy a Mobility master (MM) solution with two MM nodes. The MM solution will manage 20 MC appliance that will control a total of 800 APs.
How should the network adminstrator install the AP licences?
A. 40 AP licenses on the MM
B. 400 AP licenses on the MM
C. 800 AP licenses on each MC
D. 800 AP licenses on the MM and 40 AP licenses on each MC
what is the correct answer with explanation please..
Re: Licensing
Re: Licensing
Yes I did, But i didn't find the correct answer!
Re: Licensing
b.tibi@bahralamwaj.com wrote:
Hello Team,
I am not sure any of these answers are exactly right.  Licenses should only be installed on MMs, so that eliminates C,D.  A and B are not right because you need 800 AP licenses.  I would contact the author of the question.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
