Highlighted
All-Decade MVP 2020
MESH links on 5GHz, can 2.4GHz be disabled?
If I were to disable 2.4GHz on my MESH links, would that disturb them somewhere deep in the configuration? Would it anger the MESH Gods? Or would I be good to go as I don't need it for client connectivity.
Thanks!
Scott McNeil - Sr. Network & Security Engineer, Global Process Automation
Network+ | CWICP | CWDP | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
https://industrialwifishop.wordpress.com/
