- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
MM - 'Module xxxx is busy' message in 8.3.0.4
12-06-2018 06:20 AM - edited 12-06-2018 06:25 AM
Hi
I have a probem with my MM.
When I saved configuration (added a netdestination) in CLI under /md/ 'xx', multiple processes crashed on the MM.
The error I get is that after most issued commands, nothing happens and after a while, the message 'Module xxxx is busy' . Please try later ' will be displayed. Modeule can be License Manager, MCELL, Database Synchronization, Profile Manager, etc.
MM is the master of a HA pair. On the backup MM you can run most commands ok but it is complaining about databaseassync.
I canät access GUI on master MM and CLI occasionally hangs.
The version is 8.3.0.4. Everything in the data plan works so the users of the wireless network have no problems.
I'm considering restarting, but I'm not sure how it can affect the real wireless controls(7030).
My question is if someone else have had this problem and if so how did you solved it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
