MM not showing AP or clients
Testing 8.3 deployment with VMM and MC on same l2 subnet. AP registers with MC but do not see it on MM top display. Can update AP config from MM under controller configuration menu. Can see client under Performance but not on on Master ribbon. Have AP licenses. MC connection to VMM good. What am I missing?
Re: MM not showing AP or clients
- What version of ArubOS 8.3?
- Can you see the controllers as up on the MM?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
8.3.0.1
On the top ribbon it shows 1 controllers and no APs. If I click on the controller it shows status is good.
Sent from my iPhone
8.3.0.5 is out.  I would upgrade to that ASAP.
Upgraded VMM to 8.3.0.5 and AP now shows up. Controller upgrade comes next.
Thanks!
Sent from my iPhone
