Highlighted
Occasional Contributor I
MTBF for 7005
Hi all,
i'm looking for MTBF information about Controller Wifi Aruba 7005 (JW633A).
I need MTBF value following Telcordia Issue 3 standard: where can i find this information?
Thank you.
Highlighted
Contributor I
Re: MTBF for 7005
Highlighted
Re: MTBF for 7005
Hi Shieva,
thanks for your help.
Which standard was used for calculation? I need MTBF value following Tercordia Issue 3 standard.
Highlighted
Contributor I
Re: MTBF for 7005
I'm hoping someone from engineering can confirm my response...
It appears that it's:
Telcordia SR-332 Issue 2, Method I (Parts Count), Case 3, GB/GC (Ground Benign, Controlled) environment.
https://community.arubanetworks.com/t5/Controllerless-Networks/MTBF-of-Aruba-IAPs/td-p/86012
Highlighted
Re: MTBF for 7005
Hi Shieva,
thank you again for your help!
Is there someone from engineering who can confirm Shieva's response?
Can I have MTBF value according to Telcordia SR-332 Issue 3, method I case 3, GB?
Thank you.
