Highlighted
Occasional Contributor I
MTBF for AP-534
Hi all,
i'm looking for MTBF information about AP-534.
From datasheet:
MTBF: 995,000 hrs at +25°C operating temperature.
My question is: which standard was used for calculation? I need MTBF value following Tercordia Issue 3 standard.
Accepted Solutions
Highlighted
Aruba
Re: MTBF for AP-534
Telcordia SR-332 Issue 3, Method I Case 3
/Onno
View solution in original post
All Replies
Highlighted
Aruba
Re: MTBF for AP-534
/Onno
Highlighted
Re: MTBF for AP-534
Thanks for your help!!!
Best regards
