Re: Max EIRP by Country Code
AOS 6.5 on a US controller -
(Aruba7005) #show ap allowed-max-EIRP ?
ap-name                 Name of Access Point
ip-addr                 Filter on IP Address
(Aruba7005) #show ap allowed-max-EIRP ap-name 325 ?
|                       Output Modifiers
<cr>
I will check with engineering.
Jerrod Howard
Distinguished Technologist, TME
The power and channel limits are based on regulatory domain. Consider this Ap is provisioned in US regulatory domain profile and below command output will show the max allowed EIRP.
#show ap allowed-max-EIRP ap-name <Ap-name> country-code US
(Aruba) #show ap allowed-max-EIRP ap-name 6c:f3:7f:c7:41:bc country-code us
try: (in 6.5)
to view the current Regulatory-Cert, use the show ap regulatory command.
seems that in 6.5 cli guide..the command isnt there :(
I will find out if the removal of said command was intentional in 6.5+ or a bug :) Thanks Kdisc!
Jerrod Howard
Frequent Contributor II
any follow up? I need the Max EIRP for the USA for AP 315
Moderator
actually.... and at the risk of this snowballing the discussion:
show ap allowed-max-EIRP is deprecated (quite a while ago)
the new command is
show ap debug power-table ap-name <ap> radio [0|1]
this came about because of changes to the way we have to sum up power for multi chain APs together with beam forming etc etc.
The CLI output is lengthy, but it's somewhat self explanatory (read the info at the bottom of the output). As with the previous show ap allowed-max-EIRP it only works for an AP on the controller itself.
tl;dr; there is a new cli command which shows tx powers per rate per bandwidth per modulation per # chains etc.
