Measurement or Planning Offsets for Voice Devices
i have to plan a small "Voice Design" with Aruba and Ascom i62.
Because of the weaker Signal Strength on the phone, i have to consider the difference to my measurement tool. The Vendor recommends -65dbm for the Phone and the offset to my Wifi-Dongle is about 8db. Whats the best practice?
- A Measurement with my tool (Airmagnet) to -65dbm (in view of my stick) or
- A Measurement to -57dbm to ensure, that the phone gets -65dbm in real?
Thank you for your answers!
Kindly Regards
Ralf
Re: Measurement or Planning Offsets for Voice Devices
That is probably the best answer.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
