Highlighted
MVP Expert
Re: Mesh back to back (portal ~ point - portal ~ point)?
I've done both ways, using E0 for everything, as well as E0+E1.
Jerrod Howard
Distinguished Technologist, TME
Highlighted
Was there a solution found for this?  We are running into the same problem and have been working with TAC for some time now but still stuck with the 2nd portal not coming up.
Highlighted
MVP
Sorry, nothing to add to what has already been said in this topic.
My setup works using tunneled mode and only 2 hops.
Koen (ACMX #351 | ACDX #547 | ACCP)
-- Found a post helpful or important? Click the "Thumbs Up" icon to give kudos.
