Hi all,
Currently our client is running a 7205 pair with ~200 APs in active-standby mode, on ArubaOS6.
Plan would be to install a virtual MM, upgrade the setup to ArubaOS8, add another 7205 and another 100 APs.
I'm putting together a shopping list for this, currently I'm at:
Part Number | Qty | Desc |
JY895AAE | 1 | Aruba MM-VA-500 Mobility Master Virtual Appliance |
JW735A | 1 | Aruba 7205 (RW) Mobility Controller |
JW471AAE | 100 | Aruba LIC-ENT Licence Bundle |
R2H28A | 100 | Aruba AP-505 (RW) Dual radio 802.11ax access point |
Am I forgetting something trivial there? Do I need some licence on the MM for all APs, or the LIC-ENT sorts that out for me?
Anything I need to look out for re licence migration? I might buy the new kit from a different vendor than the existing kit, is that a problem in the mynetworking portal?
Not too worried re config migration, I have 3 PSK SSIDs, no .1x auth at the moment, so even a full rebuild shouldn't be too bad.
All info much appreciated!
Tamas
