Highlighted
Contributor II
Re: Mismatches in AirWatch
Nope ---  No changes made.  It's like the AirWave data is not be updated.
I have a case open now - maybe a resolution will come forward.  :smileyhappy:
Highlighted
Contributor II
So, since we are using AirWave to monitor only; there is a setting under: AMP Setup > General >  Use Global Aruba Configuration:  We cahnged this from "yes" (the default) to "no"  Did an import on the mismatched Master Controller and an Audit on the Local Controller.  All is well now. :smileyhappy:
