Highlighted
Re: Missed heartbeat 6.5.4.2 on several remote sites
Allright.
It suggests a connectivity issue.
You should type "show ap debug counters" to see what APs and to what extent have bootstrap issues.  It is typical to have 2 bootstraps by default.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Frequent Contributor I
That command showd alot of bootstraps and reboots.  Look at the test file.
