What functionality do you need?
The 335s and 345s are similar, with the exception that the 345 will require AOS 8.3 and can support dual 5GHz operation (both radios operating in 5GHz). Since the environment will be mixed 802.11ac wave 1 (225s) and wave 2 (3xxs), how long are the 225s expected to remain in the environment?
