Frequent Contributor I
Mobility Controller : how to change vrrp vr state from INIT to Master/BACKUP
Can someone help me to see why my mobility controller vrrp vr state is INIT?
Thanks!
Linda
Re: Mobility Controller : how to change vrrp vr state from INIT to Master/BACKUP
Did you configure it with a VLAN?
Did you give it an IP address?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Thanks for your reply.
Yes. Vlan and IP configured.
Regular Contributor I
Did you give the command " no shut ". ? This acts a start-up event and initiates advertisements.
Ajay Kumar Ravipati
ACMA (V8) | ACMP (V8) | CCENT | CCNA (R&S) | PAN-OS 8.0 ACE
Please let me know what to 'no shutdown'. ports? yes
I meant the VRRP.
Example,
VRRP 100
No shutdown
Ajay Kumar Ravipati
Done no shut on vrrp and still the same
Did you save the configuration with a "write memory"?
What is the output of " show vrrp <vrrp id> statistics "
Ajay Kumar Ravipati
