MVP
MVP
Re: Mobility MAster first time for me Configuration
Yes, all configuration will be pushed form the mobility master to the mobility controller.
On the mobilty master you create a "managed device group" and put the "managed controllers" (MC controllers) in that group. All configuration is created from the MD group. Some configuratie like IP addresses is created from the controller level.
When you like to learn more about the concept a can recommend you the excellent ABC broadcastchannel videos on youtube. That wil give you a step-by-step configuration example.
https://www.youtube.com/channel/UCFJCnuXFGfEbwEzfcgU_ERQ/search?query=arubaos
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
Regular Contributor II
Great.
Yes. Already following abc channel on youtube. Great videos there!
Thanks for the time and patience!
