Occasional Contributor I
Mobility Master Hardware Licensing
If I have rabout 1200 AP's and I need to buy hardware MMs do the hardware licenses stack? Example I buy two 1K hardware MMs I assume I just need to enable centralized licensing so my MM redundancy will have 2K support even if one fails etc rather than having to buy two 5Ks
Just want to make sure as I know these licenses are tied to the box rather than VM licenses
Re: Mobility Master Hardware Licensing
Bump, no one knows?!? :(
