Highlighted
Occasional Contributor I
Mobility Master and Mobility Controller
 Hi everyone. First of all, I am sorry if this question has already been asked.
But couldn't find the solution. Our company has bought Aruba Mobility Controller and Mobility Master
virtual appliance. We got licences. But I cannot find any downloadable link to get these products.
I have signed up on support.arubanetworks.com with the corporative email address.
But when I try to log in, it says "service contract missing".
So, my question is, how can I get the images of Mobility Master and Mobility Controller to install on VMware?
Accepted Solutions
Highlighted
MVP Guru
Re: Mobility Master and Mobility Controller
Edit - You will need a valid service contract to be associated to the email you have registered. Give TAC a call to correct if needed.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
View solution in original post
Highlighted
MVP Expert
Did you try to register into the portal using the serial number of the mobility controller
Did you register the licenses under your email account ? If not you may need to register using that other account
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
All Replies
Highlighted
MVP Guru
Highlighted
MVP Expert
Thank you
Victor Fabian
Thank you
Victor Fabian
Highlighted
thanks for replies. I was able to login with the service contract number after the distributor gave me.
