More than one RAP per site
Hello, I have a simple question,
All VRDs talk about single RAP on single site which is behind the NAT.
Is it possible to deploy   2, 3, 4 or  more RAPS per Internet Branch Site?
I have a problem than my one client has WAN network with branch offices and Internet network with branch offices.
On WAN  branch offices client can use CAP deployments, but on Internet deployments where branch sites are behind the NATs, i can only offer him RAP solution.
Client do not want to deploy controllers on branch offices, but want centralized management point, so IAP-VPN-CONTROLLER solution also is not the best offer for him with internet branches.
On internet branch offices client require from 1 to 5 APs per site.
Moderator
Re: More than one RAP per site
hi Audrius
Yes you can deploy multiple RAPs behind the same NAT, the documented limit due to fw session sync behaviour is 32 APs.
hth
-jeff
