Highlighted
Mounting for flat drywall ceiling
Hi Aruba,
I recently purchased Aruba AP 515 and want to mount it on the ceiling.  I have a flat ceiling with dry wall materials.  Please advise on what mounting kit I should get with part number and where I can get it.   Appreciate your help very much.
Accepted Solutions
Highlighted
MVP Expert
MVP Expert
Re: Mounting for flat drywall ceiling
Good resource about the AP-500 serie mount options can be find here.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=31544
De AP-MNT-MP10-D also does the job and have a smaller footprint then the AP-MNT-MP10-E, both are for flatsurfaces or wall mount.
Link to the AP-500 ordering guide here:
https://www.arubanetworks.com/assets/og/OG_AP-500Series.pdf
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
View solution in original post
All Replies
Highlighted
Super Contributor II
I would recommend a AP-MNT-MP10-E. This is a flat surface mount, and can be attached to single and dual-gang electrical boxes as well. See attached mounting options for the 5xx series.
Dustin Burns
Senior Mobility and Access Engineer @WEI
ACMX #509 | ACCX #1272 | ACSP | ACDA | ACEP | CCNP | CCDP | CCNA Wireless
If my post address your queries, give kudos and accept as solution!
Highlighted
Hi Dustin,
That's a 10pk.  Is there singles which I can buy?
Highlighted
Frequent Contributor I
Yes there are individual type-E mounting brackets available. Check the AP-5xx ordering guide for the specific part number.
Highlighted
MVP Expert
MVP Expert
Highlighted
Thank you, efisher214.
Highlighted
Thank you, mkk.
