Contributor II
Re: NETWORK OUTAGE
i agree with all the opinios i opened a case in Aruba but take to long to answer, as you reques the sh run | begin vrrp thi is the ouput
(Aruba3200-US) #show running-config | begin vrrp
Building Configuration...
(Aruba3200-US) #
I will explain more and sorry for my english but i will write as best i can, ok? I ATTACHED AND IMAGE  of the phisical configuration.
The network are working fine with only one controller the 3400, i create a VRRP instances in this controller :
vrrp 1
  priority 120
  authentication c0L1M4n&
  ip address 192.168.170.2
  description "Preferred-Master"
  vlan 170
  tracking master-up-time 30 add 20
  no shutdown
The firewall fortinet it faces to the internet and this dude is made the NAT form the public ip to the interla IP of the VRRP IP 192.168.170.2, from here everithink is ok
This Aruba3400 is in trunk in the interface GigE:
interface gigabitethernet  1/0
    description "GE1/0"
    trusted
    trusted vlan 1-4094
    switchport mode trunk
    switchport trunk allowed vlan 10,20,30,40,50,60,70,80,90,100-101,110,150,170
(Aruba3400) #show ip interface br
Interface                   IP Address / IP Netmask        Admin   Protocol
vlan 1                    172.16.0.254 / 255.255.255.0     up      down
vlan 170                 192.168.170.1 / 255.255.255.0     up      up
vlan 100                    unassigned / unassigned        up      up
vlan 101                    unassigned / unassigned        up      up
vlan 10                     unassigned / unassigned        up      up
vlan 20                     unassigned / unassigned        up      up
vlan 30                     unassigned / unassigned        up      up
vlan 40                     unassigned / unassigned        up      up
vlan 50                     unassigned / unassigned        up      up
vlan 60                     unassigned / unassigned        up      up
vlan 70                     unassigned / unassigned        up      up
vlan 80                     unassigned / unassigned        up      up
vlan 90                     unassigned / unassigned        up      up
vlan 110                    unassigned / unassigned        up      up
vlan 150                 192.168.150.1 / 255.255.255.0     up      up
loopback                192.168.170.10 / 255.255.255.255   up      up
mgmt                        unassigned / unassigned        down    down
This port is connected in trunk with the Cisco Siwtch SGE2000, and this swithc is in trunk in other port facing the fortinet, in the fortinet the customer create the sub interfaces. Each VLAN belong to each branch office we connect in the branch an RAP5WN from here all the network is working great!!! the customer is not using autentication all the ports of the RAP are trusted, authenticated allowall and tunnel mode
in the 3200 i create the same vlans number as the 3400 with no duplicate IP, only 2 VLANS have  IP address the VLAN 170 for the VRRP and the VLAN 150 for the DHCP for the wireless users in case of the primary 3400 fails
3200
(Aruba3200-US) #show ip interface br
vlan 1                    172.16.0.253 / 255.255.255.0     up      up
vlan 170               192.168.170.110 / 255.255.255.0     up      down
vlan 10                     unassigned / unassigned        up      down
vlan 20                     unassigned / unassigned        up      down
vlan 30                     unassigned / unassigned        up      down
vlan 40                     unassigned / unassigned        up      down
vlan 50                     unassigned / unassigned        up      down
vlan 60                     unassigned / unassigned        up      down
vlan 70                     unassigned / unassigned        up      down
vlan 80                     unassigned / unassigned        up      down
vlan 90                     unassigned / unassigned        up      down
vlan 100                    unassigned / unassigned        up      down
vlan 110                    unassigned / unassigned        up      down
vlan 150               192.168.150.110 / 255.255.255.0     up      down
vlan 101                    unassigned / unassigned        up      down
loopback                192.168.170.11 / 255.255.255.255   up      up
    description "GE1/0"
    trusted
    trusted vlan 1-4094
The connection betwenn cisco switches are in trunks with the sames VLANS i mentioned in this post......
A Im clear wtih my writing?
Contributor II
Re: NETWORK OUTAGE
Sathya no VRRP instances is configured in the backup conttoller im plannign to configure it but i cant because when i plug the patch cord on the port everothing comes down
