Contributor I
Re: Neato D7 problems to access the wireless network
Wild guess:
You have the latest (4.4.0-72) firmware on the D7?
WIth earlier releases I wasn´t able to manually control it when my smartphone was on 5GHz while te Robot was on 2.4.
With the latest release, the D7 is on 5GHz.
Christian
Occasional Contributor I
There's a catch-22 here: I can't update nor check the version because I can't connect to it using the app....
Perhaps I must use a spare non-aruba ap to verify this also.
https://www.mintsecurity.fi
Contributor I
I see ;-)
Have you tried to make yoru SSID 2.4GHz only?
https://support.neatorobotics.com/hc/en-us/articles/225539368-What-Wi-Fi-networks-does-my-Robot-Support-
Christian
What is the correct way of setting a SSID to 2.4G only? Setting the band to 2.4G in advanced settings and that should take care of it?
Assuming my assumption is correct, I did this and no change in how this works (does not work).
