Hi Aruba Community,
I’m busy to setup SNMP monitoring for our Aruba environment. I want to use an SNMP get to get some information from the Mobility Master. I want to ask the mobility master to give me the total number of AP’s and total number of Managed Controllers.
The problem is that I can’t find the proper OID to do this. I can use the following OID:
“.1.3.6.1.4.1.14823.2.2.1.1.3.1” But this gives me the value 0 back because there are no AP’s connected to the Mobility Master. On the Managed device this OID works fine but because of load balancing the value can be different from time to time.
Is there someone in this community who can point me to the right direction?
Thanks in advanced.
Roy Eijken
