Highlighted
Need security screes for 200 and 220 series mounts
I have 200 and 220 series WAP mounts that are missing security screws. Does anyone know where I can find some security screws?
Chintan
Highlighted
MVP Guru
Re: Need security screes for 200 and 220 series mounts
Can you confirm exactly which mounts you are referring too? There is different security screws included, for example:
T10 Torx Security Screw - AP22x
T6 Torx Security Screw - AP20x
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/26845/Default.aspx
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/26847/Default.aspx
The length of the T6 Torx is around 3cm. I don't have a T10 Torx to hand on the AP22x mount.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
