Occasional Contributor I
Newly added SSID/WLAN missing
I have gone through the Wizard in the Mobility Controller to add a new WLAN/SSID. However I do not see it after adding it. When I try to add it again, I am told that it already exists.
Am I missing something? I have already set up the IPs, VLANs, etc. for this SSID.
Thanks!
Regular Contributor I
Re: Newly added SSID/WLAN missing
what is the output of " show wlan ssid-profile " ?
Are you able to see the configured SSID here?
Ajay Kumar Ravipati
ACMA (V8) | ACMP (V8) | CCENT | CCNA (R&S) | PAN-OS 8.0 ACE
