Highlighted
Occasional Contributor I
No license for feature added
some times a feature will not be worming for example
AP not Broadcast because of the shortage license
- No license for feature added
Ho can i Troubleshoot and find the root cause ??
Highlighted
Re: No license for feature added
You can see if the license features that are enabled (or not) using the following:
cd /mm
show license-pool-profile-root
You can also use this similar but slightly different command to check  installed vs available license counts:
show license pool-profile root
Highlighted
is there any command to show logs
for example i didn't add the AP license is there any show logs command to rell that the AP is not regsited as no available license ??
Highlighted
show ap database
Check the flags for the APs, you are looking for the 'L' flag. This means unlicensed.
You may also see an error like this '<3398> <WARN> |stm|  No available license type PEFNG for AP' with the following commands:
show log system 20
show log all 20
