Re: PAPI_Send: sendto BLE Relay Controller failed
Got it.  As soon as I see the fix, I will update this thread..
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Greatly appreciated!  thanks again
syslogdwrap[1748]: PAPI_Send: sendto BLE Relay Controller failed: No such file or directory Message Code 1005 Sequence Num is 30803.
Getting N Number of Error messages from the Aruba Controller - 3400.
The fix has not been patched to any code on the website.  I will update this post when it has been patched.
It's been several years since this post was last updated and my syslog is still showing this error:
 PAPI_Send failed, send_papi_message_with_arg
Is there a way to either resolve the issue causing this message or disable the message (makes for a lot of static to go through when trying to find valid issues in my error logs).
Thanks.
- Jayson
What version of ArubaOS are you using?  What controller are you using?  What access points?
i have 3x IAP-225 devices, one of them is the master (none of them is a preferred master -- the election process is up to them).
No controller is used (other than the virtual controller they setup and shift to the current master).
IAP Firmware: 6.4.2.6-4.1.3.0_54915
Thanks.
- Jayson
The message that the user was talking about was seen on the controller platform, not IAP.  For reporting and bug purposes, it is different.  Please PM me so that we can open a case for what you are seeing.
Thank you for the clarification.
Ticket is opened.
The most current general availability is now AOS is 6.5.0.3,  Just checking to see if there has been any progress on integrating a Bug fix for this yet?
