Re: PEF Licensing Disappears After Reboot
I will say that an Aruba license is not meant to be applied to a Dell Controller.  The serial numbers are different, so I don't know how you registered the certificate ID and then applied it.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Frequent Contributor I
My apologies Colin the licenses were 'purchased' from Dell but the license keys I received came from Aruba. Nevertheless I dont really understand the position from either side (Dell or Aruba)...so far neither side is willing to help resolve the issue.
Are the license keys the only thing that disappears? Does the time stay correct?
MVP Expert
Hi Tim,
Did you perform one of the following steps post adding licenses:
1. Execute the command "wr mem" from CLI
2. Clicked on "Save configuration" option from WebUI.
No issue with losing the time or anything else I can see. The AP & POE licensing stays as well.
Yes I have tried the WebUi, WebUI wizard and the CLI always saving the config and all with the same results.
One thing I haven't tried is a factory reset just not sure that would change anything as I would need to restore the config anyway. Would it make any sense to go back to a previous OS version? I have 6.2.1.9 on partition 1
By chance does Aruba offer single incident support?
MVP Expert
Hi Tim,
Please open a TAC ticket as this could be firmware related issue as well.
Thank you for your response. The unit is currently not under any maintenance/warranty agreement and is a Dell branded unit. Dell will not warranty the unit nor will their 3rd party service provider.
Does Aruba do per incident support? Would they support a Dell branded unit?
