Highlighted
Super Contributor II
Portable solar powered AP solution?
Does anyone here have any experience building kits for solar powered mesh AP deployments, or know where to point me for prebuilt setups? Preferably a portable, quick deploy type of build? I'm trying to piece things together, but everything I'm looking at right now weighs about 200 pounds!!
Dustin Burns
Senior Mobility and Access Engineer @WEI
ACMX #509 | ACCX #1272 | ACSP | ACDA | ACEP | CCNP | CCDP | CCNA Wireless
If my post address your queries, give kudos and accept as solution!
Highlighted
Re: Portable solar powered AP solution?
Have you checked with this company?  https://solisenergy.com/
https://solisenergy.com/product/solar-power-plant/
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Yes I have, thanks. I'm trying to get a couple ideas together for a customer for an outdoor mesh for daily events. Interested in any full APoaS solutions that people have deployed in the past.
Dustin Burns
Highlighted
Are you talking something like this or much smaller?
Highlighted
Haha that's awesome. I was hoping for something smaller, that could possibly be packed into a pelican case.
Dustin Burns
Highlighted
We would need more details:
Which AP model?  How long do you want to run it outside per day?  If you are going to run it 24/7, you would have too much equipment to be in a pelican case...(solar panel + batteries for a device that consumes 30watts 24/7 with only 4 hours of usable sun).
Highlighted
I would say 8 hours of uptime. Thinking a survey battery being charged while in use by a solar panel. I know that the AccelTex site survey batteries can be charged while in use.
Dustin Burns
Highlighted
MVP Expert
MVP Expert
For surveys i run on a 50.000mah powerbank with use the 12v output that can runs 3 days without active clients on a AP-305 or AP-505. Don't no what happens  when it have load of many clients. Can be charged while using.
Poweroak have also some other products with solarpanals.
https://poweroak.nl/en/powerbanks/10011-poweroak-poweroak-k2-solar-185wh-50000mah-laptop-powerbank-8719324080118.html
This powerbank can't fly ;).
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP | Ekahau ECSE Design - Was this post usefull, Kudos are welcome.
