Hello, I have the exact same issue downgrading from 8.6.0.5 to 6.5.4.11
I tried to tftp from the cli: it didn't downgrade for unknow reason. No log, no message nothing... And the image stayed at 8.6
I tried from Http: and I had the invalid image message
I must write that the http source download field specify "ursa" so I'm pretty sure my file is alright (since it specifies ursa in the filename and I got it from the Aruba software download website) .
BTW, if you would give firmware upgrd to IAP 105 which is half of our 300+ access points, I wouldn't have to struggle with this. This original post is 1year + old and I do not get why it is written as "solved".
Also, on a side point, can you please do something with you auto translation? It is not good at all since it auto translates technical terms with poor acuracy.
Additionaly It is impossible to deactivate the feature... it is very disturbing to be pranked all the time by this almost understandable translation bot
