Hey,
i have a problem establishing a mesh between two APs, one AP-365 (Mesh Point) and one 205H (Mesh Portal).
We are using two 7210 controllers with 8.4.0.0 software. I created a new AP group for the two access points and created a new Mesh Cluster. I checked in the profile that the default Mesh radio is there.
I provisiond the 205h as the Mesh Portal, everthing okay with it. Then i provisioned the 365 as the Mesh Point and it won´t create a connection with the portal.
Any advice where i can find further information for the troubleshooting?
Thanks in advance,
Daniel
