Regular Contributor I
Re: Problems with Split Tunnel SSID
Yes, I tested it in a extra vlan, there is a dhcp relay in the vlan and the dhcp works fine for the ssid in tunnel mode...
What can I test next?
Tunnel mode goes back to the controller and will DHCP from either the controller or upstream.
You need DHCP in the local subnet where the AP is connected.
Tim
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
yes, there is a dhcp in the subnet, the lan connected clients does dhcp in this subnet, and the AP get a IP in this subnet, too.
Leon123,
What is your ACL for split users..?
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Sorry i found my mistake.
I must put the vlan id 1 on the ssid configuration to use the untagged vlan the AP is connected to.
Sorry guys, shame on me ;-)
