Regular Contributor I
Re: Problems with Split Tunnel SSID
Ok, thanks.
It means the bridge ssid configuration set the complete AP in bridge mode with all ssids on it.
when you set bridge, it is only applied to the VAP you are changing.
You can have a combination of several ssids with different forwarding modes.
ACCP, ACCX #817, ACMP, ACMX #294
Ok, thanks,
So I can set up a Employee ssid in bridge mode and a guest ssid in tunnel mode on the same ap right?
Have you a set up guide or a step by step guide to set up a ssid in bridge mode?
So I can set up a Employee ssid in bridge mode and a guest ssid in tunnel mode on the same ap right?  --> Yes
Have you a set up guide or a step by step guide to set up a ssid in bridge mode?  --> Good place to start is the RAP design guide here.
To make an ssid to be bridged.
forward-mode bridge
no broadcast-filter all
no broadcast-filter arp
But i want to use the APs as Campus APs not as RAPs
I Bridge mode only supported on RAPs?
I test it, but the ssid is not broadcasting on my aps!
It is allowed on Campus APs if you have control plane security enabled on your controller.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
Do you have control plane security (CPSec) enabled?
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
now it is enabled and the ssid is broadcasting, but i don not get an ip adress when i try to connect
Does the local subnet have a DHCP server or DHCP relay configured?
