Questions about AP-303HR functions and E0/E1/E2/E3
  • 1.  Questions about AP-303HR functions and E0/E1/E2/E3
    Posted Jul 29, 2020 01:15 PM
    AP303HR is listed as a remote AP. Is it Unified?
    Are the E1 E2 E3 interfaces configurable? If so how?
    I want to use the AP303HR as a campus AP and utilize the 3 other
    interface for separate vlans.
  • 2.  RE: Questions about AP-303HR functions and E0/E1/E2/E3
    Posted Jul 29, 2020 01:24 PM
    Yes, AP-303H(R) ships as a unified AP, and can be used with controller (AOS) or without (Instant). Port configuration is no different from any other AP with multiple ports.
  • 3.  RE: Questions about AP-303HR functions and E0/E1/E2/E3
    Posted Jul 30, 2020 11:05 AM
    Thanks Onno.
    Can you steer me to the documentation for configuring multiple ports?
  • 4.  RE: Questions about AP-303HR functions and E0/E1/E2/E3
    Posted Jul 30, 2020 01:49 PM
    I cannot, but hoping someone else can.
  • 5.  RE: Questions about AP-303HR functions and E0/E1/E2/E3
    MVP GURU
    Posted Jul 30, 2020 02:52 PM
    These links should give you enough information to get going:
    https://www.arubanetworks.com/techdocs/ArubaOS_80_Web_Help/Content/ArubaFrameStyles/1CommandList/ap_wired_port_profile.htm
    Basically you create a wired port profile, and then apply them to the interfaces that you want it on. Try not to use Eth0 though, as this is sually your APs uplink port.
    Attachment(s)
  • 6.  RE: Questions about AP-303HR functions and E0/E1/E2/E3
    Posted Aug 01, 2020 09:04 AM
    That works. All good, thanks!
