Highlighted
Frequent Contributor I
Quick AP vs IAP Question
I have a lot of IAP-205 running via AirWave. We just aquired a new company's wireless and they have all AP-105 running via standalone 3400 controller. My question is will the AP-105 work on AirWave like the IAP-205's? I would like to manage them from AirWave vs the 3400 controller.
Highlighted
Community Manager
Re: Quick AP vs IAP Question
Yep, you would add the controller to Airwave and manage the controller and APs via Airwave.
*Be sure to import the config for the template to manage the controller. I forgot this once, will never do it again.
Airheads Community - The best place to Connect, Engage, and Learn
Highlighted
MVP Expert
I recommend you continue managing your AP-105s via the 3400 controller but you can manage those via AirWave
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Highlighted
EDIT: didnt see the other reply before i posted the below response. thanks for the imformation from both of you.
if i dont want to use the controller and just add the Ap-105s to AirWave will that work?
Highlighted
MVP Expert
Are those IAPs or Aps? You can take a look at the back of the AP
Sent from Mail for Windows 10
Thank you
Victor Fabian
Highlighted
i believe they are AP's and not IAPs. how can i tell via the 3400 controlller.
