Re: RAP Backup SSID Problem
Change the VAP vlan to 1 to make sure the user gets an ip address from the same subnet as the AP (hopefully there is DHCP on that subnet).  I am not sure if you wanted the user to get an ip address from the AP or not...  If you do, the VAP vlan from the backup must match the DHCP VLAN in the AP system profile of the AP.  Also the user role must be something that source-nats the traffic out of the AP, not just authenticated.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
