Highlighted
Frequent Contributor II
Re: RAP configuration on 6.4
Its a 205.
I have to get a RAP3 working, but I switched to the 205 for troubleshooting purposes...
Highlighted
Moderator
Both the 205 and RAP-3 have TPM chips so they will have a factory certificate.
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
Highlighted
I dont have a 4500 session coming across anymore.
Highlighted
Moderator
hi playinpearls
cert rap bring up should require the following few steps only. no vpn profiles, no PSKs etc.
Controller
>> define l2tp ip pool
>> whitelist the ap
AP
>> purge ap (or reset via button, making sure it doesnt revert to IAP if it was instant before)
>> check you working DHCP (type dhcp at apboot, wait, then ping the master ip - make sure it's all fine)
>> either let it discover and connect to controller, reprovision as rap, or from apboot
   setenv remote_ap 1
   setenv master  <controller ip>
   save
   boot
that should be it, if it's still stuck after this, you can go into the ap shell and take a look in the file /tmp/rapper.txt and /tmp/sapd_debug_log.txt, these may give you a hint as to any problem. But ultimately, setting it as RAP above and the master IP should be enough to get it talking to the controller.
regards
-jeff
Highlighted
thanks Jeff, thats what I was looking for.
It turns out that we had the RAP natting through a firewall that wasn't the gateway of the controller, so it was failing at making a complete circle. The controller was sending replies through a different firewall.
