Highlighted
Re: RAP failover
It works, it was pool,
Thanks, good catch
Highlighted
MVP Guru
Re: RAP failover
No worries! Glad to hear it is sorted!
Sent from my iPhone
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
Highlighted
Re: RAP failover
Hi again,
Now there is another problem connected with this setup. I know RAP failover works while both controllers are UP. I did a test and hard reset MASTER controller, SLAVE was still up but RAP did not connected as tested before just by "cutting off" master IP.
Both controllers are in the same place and on the same subnet. Why it does not work now? Does this have sth to do with hearbeat, how to fix it?
Highlighted
Re: RAP failover
How are you making the RAP failover to the local?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Re: RAP failover
my master is x.x.x..54
my local is x.x.x..53
My RAPs are setup like that
setenv remote_ap 1
setenv master x.x.x..54
setenv serverip x.x.x..54
Then in the AP system I have LMS IP settings which I did not touched but contain both IPs .53 and .54
And they are triggered by Bootstrap threshold and max time, which works only in case I simulate master failure by firewall block of MASTER IP.
Highlighted
Re: RAP failover
Any idea, what I am doing wrong?
Highlighted
MVP Guru
Re: RAP failover
There could be numerous reasons as to why the secondary RAP is not appearing on the standby controller (missing whitelist entry, RAP pool not configured etc). In the very first instance do you see the RAP traffic on the standby controller?
show data path session | include [RAP external IP]
Highlighted
Re: RAP failover
Not sure what you mean by "standby controller" but my configuration is MASTER - LOCAL
1) Local does have copy of configuration from master synching in real time
2) RAP whitelist does include all RAP MACs like on master
3) local does have RAP pool - it works by what I mean RAP do failover to LOCAL if both controllers see each other meaning they are online connected to the same swtich/vlan
4) problem starts once MASTER is shutdown, no power
5) cant verify that now
6) what I did notice is when I shutdown MASTER and waited 10 min, none of RAPs synched to LOCAL but if I made MASTER back up I realized some RAPs instatnly popup up on LOCAL which may prove there is some hartbeat issue in my setup. Is that possible?
Highlighted
Re: RAP failover
Does that make any sense?  Is there a hearbeat existance in my setup?
Highlighted
Re: RAP failover
Let me ask you like that:
1)  Will RAP redundacy work with MASTER/LOCAL setup only (No NAT)?
2)  Will RAP redundacy work with VRRP (MASTER ACTIVE / MASTER STANDBY) using 3 public IPs (no NAT)?
