Highlighted
RAP split tunnel or bridge mode vs Campus AP in bridge mode?
Hello.
Please could you help me with this configuration doubt?
I have read a lot of topics about this discussion but really I can´t find a clear solution for this deployment.
Our customer has a Headquarters with a couple of 7030 Controllers in a Master standby fashion.
A new branch office with five Aps needs to be deployed. Both offices will be connected through a MPLS.
Three corporate SSIDs must be broadcasted in the branch office, two of them with 802.1x authentication against a ClearPass PM located in the HQ.
There is a Guest SSID with captive portal too, and as far I have understood this one is not supported in bridge mode.
Our customer wants wireless clients in the branch get their IP address from a local DHCP server, besides in the case of WAN failure the Access Points in the branch must remain active with the connected clients (those that were connected before the link failure).
RAP with split tunnel mode doesn't support local dhcp addressing for clients connected to the 802.1X SSIDs.
Is there any kind of configuration that supports two SSIDs in bridge mode with another one in tunnel mode under the same AP-Group?
What kind of configuration do you recommend me?
Thank you in advance.
Regards.
Highlighted
MVP Expert
Re: RAP split tunnel or bridge mode vs Campus AP in bridge mode?
Are those Aps = IAPs ?
You could use the distributed DHCP L3 option
The IAP build a VPN tunnel back to the Aruba controller acting as a VPN concentrator and the DHCP will be handled by the IAP (stays local) and you can also configure it in split tunnel mode
It is explain here in the Aruba Instant VRD
https://community.arubanetworks.com/aruba/attachments/aruba/Aruba-VRDs/76/2/Aruba_Instant_VRD_2016.pdf
Sent from Mail for Windows 10
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Highlighted
Hello Victor.
No, they aren't. All access points are Campus APs.
Thank you so much for your fast answer.
Regards.
Highlighted
Hi!
Do you think the deployment I was talking about could be done with Campus Aps?
Maybe the customer's requeriments for the branch office can't be achieved neither with Raps in bridge or split tunnel mode nor Campus Aps in bridge mode.
Any suggestion would be welcome!
Thank you so much.
Regards.
Highlighted
MVP Expert
Because the AP traffic will be traversing the WAN this deployment may not be optimal
Another option could be to have a smaller controller (7005) at the office
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
