RAP with Mobility Controller Cluster AOS8.4
I'm trying to find some technical documentation or some explication about how to configure Remote Access Point with a Mobility Controller Cluster having 1 Public IP Address for both Controllers.
I heard that NAT wasn't supported with this design on the previous AOS8 versions but that it was ok on the AOS8.4. I can't find any documentations about that.
Could you help me?
Regards
MVP Guru
Re: RAP with Mobility Controller Cluster AOS8.4
Now in AOS 8.4 you can define the controllers NAT Public IPs in the Controller Cluster config
Thank you
Victor Fabian
Pardon typos sent from Mobile
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Thank you Victor
Hello again,
I configured my cluster with a Public IP on each, but I still don't get how my RAP will get both of these IPs as in the configuration of the RAP we only can advise 1 Public IP on it.
Christophe
