I've had some random issues with a few RAPs in the last few days. Only a few users, and I chalked it up to flaky home internet. But this one is getting a new tunnel IP exactly once/day at 16:08. When it does, the user gets dropped from wifi. Is there a timeout?
AP303H on a 7220 MD running 8.5.0.6.
Thu Apr 2 16:09:29 2020 System Tunnel IP changed from 169.254.5.254 to 169.254.6.32.
Thu Apr 2 11:55:37 2020 System Status changed to 'OK'
Thu Apr 2 11:55:37 2020 System Up
Thu Apr 2 11:15:24 2020 System Status changed to 'Controller is Down'
Thu Apr 2 11:15:24 2020 System Down
Wed Apr 1 16:09:26 2020 System Tunnel IP changed from 169.254.5.210 to 169.254.5.254.
Tue Mar 31 16:09:08 2020 System Tunnel IP changed from 169.254.5.172 to 169.254.5.210.
Mon Mar 30 16:04:09 2020 System Tunnel IP changed from 169.254.5.169 to 169.254.5.172.
Mon Mar 30 16:03:17 2020 System Status changed to 'OK'
Mon Mar 30 16:03:17 2020 System Up
Mon Mar 30 16:03:17 2020 System Device rebooted while marked as down: Device uptime value changed (current: 4 mins 29 secs, calculated: 41 mins 41 secs) and
Change in number of reboots detected (got 19, expected 17)
Mon Mar 30 15:58:19 2020 System Status changed to 'AP is no longer associated with controller'
Mon Mar 30 15:58:19 2020 System Down
Mon Mar 30 15:34:09 2020 System Tunnel IP changed from 169.254.5.164 to 169.254.5.169.
Mon Mar 30 15:28:16 2020 System Status changed to 'OK'
Mon Mar 30 15:28:16 2020 System Up
Mon Mar 30 15:28:16 2020 System Device rebooted while marked as down: Device uptime value changed (current: 6 mins 40 secs, calculated: 2 hrs 55 mins 39 secs) and
Change in number of reboots detected (got 17, expected 15)
Mon Mar 30 14:58:15 2020 System Status changed to 'AP is no longer associated with controller'
Mon Mar 30 14:58:15 2020 System Down
Mon Mar 30 12:49:16 2020 System Tunnel IP changed from 169.254.5.162 to 169.254.5.164.
Mon Mar 30 12:38:12 2020 System Status changed to 'OK'
Mon Mar 30 12:38:12 2020 System Up
Mon Mar 30 12:38:12 2020 System Device rebooted while marked as down: Device uptime value changed (current: 5 mins 35 secs, calculated: 46 mins 13 secs) and
Change in number of reboots detected (got 15, expected 13)
Mon Mar 30 12:33:13 2020 System Status changed to 'AP is no longer associated with controller'
Mon Mar 30 12:33:13 2020 System Down
Mon Mar 30 12:08:21 2020 System Status changed to 'OK'
Mon Mar 30 12:08:21 2020 System Up
Mon Mar 30 12:08:21 2020 System Device rebooted while marked as down: Device uptime value changed (current: 16 mins 12 secs, calculated: 9 days 19 hrs 33 mins 29
secs) and Change in number of reboots detected (got 13, expected 11)
Mon Mar 30 12:04:06 2020 System Tunnel IP changed from 169.254.4.111 to 169.254.5.162.
