Frequent Contributor I
RAWR NO UCC INFO IN MM
Yes I saw other topics but I've tried the solutions listed there.
(Openflow Controller) MM <->MD (Openflow Agent)
Confirmed Openflow Controller enabled on MM: MM->Config>Prof->Controller Profile-> Openflow-control -> ofc state checked. No other settings changed from default
Confirmed Openflow enabled EVERYWHERE. SSID/ROLE/OPENFLOW-PROFILE at MD level.
Testing via a wireless client with S4B Test call. 5+ calls
All controller rebooted.
Its gotta be something silly.........
Re: RAWR NO UCC INFO IN MM
(SDC-VMC1) [MDC] #show openflow controller
Controller IP Address: 10.60.10.1 Port: 6633
Connection: UP
State: ACTIVE
Local IP: 10.61.11.2
Local Port: 40702
Last Connected: Mon Oct 14 21:00:37 2019 (5953 seconds ago)
Datapath ID: 00:00:00:0c:29:7c:56:82
Auxiliary Channel Status:Off, Last Connected: Wed Dec 31 19:00:00 1969
Total Flow Count: 25
Total Port Count: 16
Total Packet In Count: 17622
Total Packet In Count (no match): 10
Total Packet Out Count: 47
(SDC-VMC1) [MDC] #
(PDC-VMM1) [mynode] #show openflow-controller switches
Switches
Dpid IP Version Status Auxiliary-Status/Id Capabilities Description
00:00:00:0c:29:7c:56:82 10.61.11.2:40709 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 SDC-VMC1 MCA7C5678
00:00:00:0c:29:b9:aa:59 10.60.11.3:33300 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 PDC-VMC2 MCFB9AA4F
00:00:00:0c:29:34:11:0d 10.60.11.2:46164 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 PDC-VMC1 MC9341103
00:00:00:0c:29:1b:84:5f 10.61.11.3:49682 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 SDC-VMC2 MC31B8455
Total number of switches: 4
Wireshark showed some STUN packets get spit out when doing a S4B Test call. Any other tools out there that could generate some traffic UCC would gobble up?
AHH DISABLED THE OPEN-FLOW-STATE..
WAITED FOR THIS:
Switches
00:00:00:0c:29:7c:56:82 10.61.11.2:40709 v1.3 Down Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 SDC-VMC1 MCA7C5678
00:00:00:0c:29:b9:aa:59 10.60.11.3:33300 v1.3 Down Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 PDC-VMC2 MCFB9AA4F
00:00:00:0c:29:34:11:0d 10.60.11.2:46164 v1.3 Down Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 PDC-VMC1 MC9341103
00:00:00:0c:29:1b:84:5f 10.61.11.3:49682 v1.3 Down Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 SDC-VMC2 MC31B8455
ENABLED OPENFLOW STATE
Switches
00:00:00:0c:29:7c:56:82 10.61.11.2:40710 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 SDC-VMC1 MCA7C5678
00:00:00:0c:29:b9:aa:59 10.60.11.3:33301 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 PDC-VMC2 MCFB9AA4F
00:00:00:0c:29:34:11:0d 10.60.11.2:46165 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 PDC-VMC1 MC9341103
00:00:00:0c:29:1b:84:5f 10.61.11.3:49683 v1.3 Up Down/0 Flow stats, Table stats, Port stats, Queue Stats Aruba Networks, Inc. MC-VA ArubaOS, 8.3.0.6 SDC-VMC2 MC31B8455
And magic...ARGH
(PDC-VMM1) [mynode] #show ucc client-info
Client Status:
Client IP Client MAC Client Name ALG Server(IP) Registration State Call Status AP Name Flags Device Type Home_Agent Foreign_Agent
10.228.1.153 a0:88:b4:c9:03:c0 Client Skype4B REGISTERED In-Call G1-AP-205 Win 8 10.60.11.3 NA
